vcTransportInStatementBase
Base class for transport in statements.
Parent: vcTransportStatementBase
Children: vcStartTransportInStatement, vcTransportInStatement
AssemblyVariableNameStringRWGets or sets the name of a process variable that references the assembly instance to start filling or emptying. Used in process assembly mode.
FiltervcProductFilterRGets the filter.
ProductPositionFramevcFrameFeatureRWGets or sets the position and orientation where the product instance should be placed. Must be from the same component.
ReservedProductVariableNameStringRWGets or sets the name of a variable containing products already reserved using Reserve Product statement. If defined, the statement will transport in those specific products.
SourceStringRWGets or sets the source which determines whether to use the transport system or a container.
demoteFromCombinationFiltervcProductFilterNoneDowngrades back to filter, filter count must have 1 or 0 filters.
vcProductFilter: The modified filter.
TypeError: When the filter is not a CombinationFilter.
TypeError: When CombinationFilter has more than 1 sub-filters.
promoteToCombinationFiltervcProductFilterNoneUpgrades current filter to combination filter.
TypeError: When the filter is already a CombinationFilter.
replaceFromvcProductFiltervcStatement statementSets filter from other container.
statement (vcStatement): The statement to replace the filter from. Has to be a statement with a filter container.
AttributeError: When argument is a statement without a filter container.
setFiltervcProductFiltervcProductFilterType filterTypeSets to specific filter.
filterType (vcProductFilterType): The type of filter to set to.
vcProductFilter: The new filter.
AttributeError: When the argument filterType is ProductType.
NameParametersDescription
OnFilterChangedNoneTriggered when filter is changed.
